JeepSheep
I got a set of Unofficial Use Only OEM Plus Door Pockets (see here: unofficialuseonly.com) and decided to put them to the test! I figure that if they are going to make a plastic pocket and call it OEM quality that it should be able to hold up to some abuse. I put some scrap steel in a bucket and hung it off the edge of the pocket. The front door held 35.1 lbs before I was worried that my clamp would come off the edge due to it bowing out so far. After I removed the weight the pocket went right back to its original location and had no permanent deformation! I could have added more weight! The rear door held 41.2 lbs because that is all that I could fit in my bucket. It also went right back to normal but with the connection points in the corners being a bit looser than before testing. I am beyond impressed with the durability of this US made product! I shared my results with UUO and they gave me a 25% off promo code that I can share with anyone who can send me a photo of them testing their aftermarket door pockets in this way. Lets start a leader board of the aftermarket door pockets! Which brand can hold the most?
