ABS Traction control issue
Machine27
David Nyman
San Antonio TX
2022 Jeep Gladiator Rubicon
Here's a head scratcher...
My 2022 Gladiator Rubicon has had a few mods. Dynatrac axles, AEV suspension and wheels etc.. Recently, it's started a host of issues I can't figure out.
Here are the symptoms:
Speedo surges when turning to the left
Anti lock surges the peddle when turning to the left and slowing down
Cruise control surges, again when veering to the left.
I've replace both front wheel speed sensors.
I've got the Tazer so I can turn off the ABS/traction control but the speedo will still surge wildly when turning to the left.
My steering wheel is almost dead center so I'm ruling out the encoder in the steering wheel.
I dread taking it back to the dealer.
Any ideas?
Any ideas?
Have you checked or replaced the passenger rear abs speed sensor? That wheel rotates faster when turning left.
Machine27
Machine27
David Nyman
San Antonio TX
I plan to replace both rear sensors next. Was hoping someone out there has seen this before.
I haven’t seen that symptom. Hopefully someone else has. I’ve just seen the rears get stretched if the wire is too short with long travel. The fronts seem to have plenty of slack on mine, but I extended my rears as thy were way shorter than my brake lines.
Machine27
Machine27
David Nyman
San Antonio TX
That's something I hadn't considered. I will change mine out and check the length. Thank you!
I’m just throwing out ideas. Hopefully that’s the culprit. I lengthened mine. I detailed the project in another thread. I’ll look for it if you’re interested.
Machine27
Machine27
David Nyman
San Antonio TX
Here's an update. I'm hoping this helps anyone in the future that finds themselves with this issue. I changed all the wheel sensors with no improvement. Keep in mind I never got a light on the dash indicating a problem, everything was drivability issues.
Finally last night I pulled off the rear tires to check if the tone rings were dirty. The driver's side ring was broken free from the axle shaft and just spins freely.
I contacted Cory at Dynatrac and they immediately agreed to send me a replacement axle shaft. Kudos to Dynatrac for standing behind their products. I'll be buying from them again.
Thanks for the update. So the tone ring comes with the axle in the rear? Sorry for my ignorance. I’ve only pulled front axles so haven’t looked at the rears closely.
Machine27
Machine27
David Nyman
San Antonio TX
Yes. I have the XD 60 Profloat 5 lug axles and I understand there are two sets of outer bearings instead of just one. The tone ring appears to be installed between the bearings and the wheel mount flange. By changing the whole axle shaft, I won't have to remove the bearings to get at the tone ring. The axles are Chromoly 35 spline axles so I'll get a chance to see one up close when the new one arrives.
Great to hear. Glad they made it easy ish for you to fix.
