Audio Equalizer Settings - Not Saving in Memory - resets to default
Appalachicola
2020 Jeep JL Sport S 2-door
Self employed
Hey all…
2020 Gladiator, 7” UConnect screen. Audio equalizer settings not saving.
Just as it reads, when I go to the Audio settings to adjust the equalizer settings, change treble, mid, and bass, then exit screen and drive on, stop, turn off & exit Jeep. Next time I get in, start Jeep, the audio equalizer settings are back to default (middle setting treble, mid, and bass). Not a good sound (flat).
I did install the ZAutomotive TaZer Mini, it remains plugged in. To my knowledge, there are no settings in the TaZer Mini setup that disrupt the audio equalizer.
I assume this is the culprit.
Anyone else have this issue?
sass JT
Bryan
youtube.com
MWD
Do a tazer reboot and 2 full sleep cycles. If it doesn’t work, unmarry your tazer and check to see if your eq setting will stay.
ForgottenCoastJT
Appalachicola
Self employed
Thanks sass JT. Will do first thing in the am and report back.
ForgottenCoastJT
Appalachicola
Self employed
Thanks sass JT!
Today I performed a reboot on the Tazer menu, followed by 2 full sleep cycles. Drove the Jeep multiple times today, and the eq settings did not reset, stayed to my personal settings. This worked!
Appreciate the help
