JEEP WRANGLER JL COLORSHIFT® FIBER OPTIC LED INTERIOR KIT
ORACLElights
Peak Sponsor (Level 2)
Metairie, LA
www.oraclelights.com
Jeep Gladiator
Automotive LED Manufacturer
ORACLE Lighting’s new Fiber Optic Interior Kits are the perfect way to accent your vehicle’s dull interior in a clean and seamless way. The special side-firing fiber optic cables have an integrated edge to make installation easy on your Jeep Wrangler JL or Gladiator JT. Using the included installation tool, insert the integrated edge between interior body panels in your vehicle including door panels, dashboard, headliner, console, and more. The power cord adapter has a switch to turn ON and OFF the lights conveniently.
Jeep Gladiator JEEP WRANGLER JL COLORSHIFT® FIBER OPTIC LED INTERIOR KIT ORACLELighting_4231-333-1_AX_1024x1024
Jeep Gladiator JEEP WRANGLER JL COLORSHIFT® FIBER OPTIC LED INTERIOR KIT ORACLELighting_4231-333-1_BE_1024x1024
Jeep Gladiator JEEP WRANGLER JL COLORSHIFT® FIBER OPTIC LED INTERIOR KIT ORACLELighting_4231-333-1_BA_1024x1024
How It Works:
The fiber optic is end lit by a LED light head. We recommend that for any length over 3’, you end-light both ends of the cable for the best and brightest look. The light travels through the fiber and lights up smoothly along the way for a very clean and understated appearance. The integrated edge is designed to hold the fiber optic cable tightly without the use of any adhesive.
Our ColorSHIFT option comes with a remote that allows you to select the exact color you want to use, adjust the brightness, and even do different effects like pulse, strobe, and smooth color transitions. You can also control your fiber optic interior kit using the free app called "LED LAMP." Available for Android and IOS.
Installation Video:
Reminder to use your FORUM10 discount code for 10% off!
MPMB
Michael
Utah
'21 JTR - SG
Check your inbox.
Cool.
1-up the awesome factor. A clear panel over the gauges and passenger side that is overlaid with a topographic layer (vinyl/hydrodipped/whatevs), where the elevation lines are clear or white (not light blocking). Light the panels from behind.
