Fabtech Motorsports
Peak Sponsor (Level 2)
CA
Bronco, jeeps, trucks
TL/DR
Take your Gladiator to the next level with our suspension system and Dirt Logic coilovers.
We offer a 3" system as well and various shock options to pair with the suspension system you choose.
Fabtech’s Jeep Crawler long arm system with the Dirt Logic 2.5 Coilover Conversion is the pinnacle of Jeep suspension performance. The ride quality of this kit is outstanding with the ability to endure severe offroad use that is suited for core rock crawlers, overlanders or for those that just want a plush ride.
The conversion includes heavy duty 1/4" thick steel bracketry that attaches to the side of the Jeep coil spring bucket and to the frame for stout mounting of the Dirt Logic Coilovers. The Dirt Logic 2.5’s Coilovers are the only all stainless steel body shock on the market. This is the most corrosive resistant shock there is. The ride quality of these Coilovers are vastly superior to a coil spring and shock configuration. This is the single biggest improvement you can do to your Jeep Gladiator to enhance the ride quality both on and offroad.
A key part of the Crawler system is the link arm geometry. The location of the link arms to the frame is critical in providing superior handling throughout the travel range. Fabtech has found the sweet spot geometry for the link arms that provide a superior driving Jeep long arm system compared to all others on the market.
Front link arms are mounted to a full width crossmember that spans frame rail to frame rail. This crossmember is a key in not only in mounting the Links arms at the correct geometry but it adds critical strength to the Gladiator frame for hard offroad use. Rear links attach to the factory frame and axle brackets for an easy install.
The Fabtech lower Link Arms are massive and built of 2" OD .313" thick wall tubing that is guaranteed not to bend. Upper and lower Link Arms includes the Fabtech’s legendary 5 Ton joints® that come with lifetime guarantee of never wearing out. They are superior for offroad use with a smooth and quiet operation on the street.
Each Fabtech component has been designed with specific features and benefits that create this quality suspension system.
Another thing that sets us apart, Fabtech's reputation for building the finest suspension systems is now backed by an unprecedented 5 year 60,000 mile FIVE SIXTY Powertrain Warranty.
The link:
https://fabtechmotorsports.com/prod...ers-rear-dirt-logic-2-25-resi-shocks-k4180dl/
Fabtech Motorsports
Fabtech Motorsports
CA
In this case, they are a 40" tire since it is paired with our high-clearance fender.
You can run a 40" with any high clearance fender.
Otherwise, built around a 37" tire.
What size tire is on the red Gladiator?
JTGuy
Pascual
San Dimas CA
20022 Jeep Gladiator
Manager
Looks like a good system but I finally got mine all set on my 37s and not willing to start over. Time and $$$$$ are done.
Fabtech Motorsports
Fabtech Motorsports
CA
I hear you!!! Enjoy your JT!!!
