SS3 max fog problems
Aleph
Alaska
2023 Gladiator Mojave
I'm having the same issue but with my Baja Designs Squadron Pros either when I stop at a light or when I turn sharply like pulling into a parking spot or backing into one. Did anyone find out a fix to this issue? And my stopstart is always off so that can't be the issue.
I know I’m reviving a very old thread, but the same issue has been happening to me with my DD SS3 max fogs. This thread has given me a bit of insight. I always drive with my start stop off and they turn off on me, especially when turning. My theory is that it is probably the power steering drawing power that turns them off. It might be a limitation from the OEM fog harness that they connect to.
If that’s the case, I’m not sure what I can do about it though.
Rick_Jame55
Rickel
2021 Gladiator
QA Inspector
Curious if I’m the only one. Several times now I’ll be sitting at a traffic light and my SS3 fogs will turn off. First one and then the other. The turn signal is on and the start/stop system is active every time this happens. I can get the lights to turn back on, but only by shutting the engine off. Took it back to the shop and everything is wired correctly and the lights do work on startup. Beginning to feel like I wasted $500.
I have the SS3Pro’s. Had the same type issue when I installed them. Except both would come on the one side would shut off. Long story short you need to set the fog light setting to halogen. The led setting doesn’t provide enough power. At least it worked for me. Going on 4.5 years now!
DAVECS2
Dave
Chillicothe, IL
2020 Gladiator
I would try the halogen setting, if that does not work, you need an inline relay harness.
