$1000 Budget for Handling Improvements - Best Parts for Highway Wandering?
mtbjeeper
MA
2018 JLUS
Agree with what many others have said; it will never be perfect as it is a live front axle vehicle, but we aren't shooting for perfect here with these vehicles. On a stock vehicle start with the basics before you spend money:
1. Get an alignment and keep the printout of the before and after. As you make changes down down the road you'll have a frame of reference;
2. When you do the alignment have the shop give you a little toe-in. Jeep wandering, especially on un-even pavement, can be helped with a little toe-in which will help you track straight;
3. Have the shop check for loose bolts on the steering and suspension;
4. Tire pressure. I have found this to affect live axle vehicles far more than IFS. Too much air and the tire will ride on a narrow center crown as the tire bulges out. Not only does this lead to abnormal wear along the center of the tire, but the tire can "fall off" this crown to either side. Depending on road conditions this can cause the jeep to wander as the crowned tires hunts to the left and right. You need to get the pressure down to where the tread is flat; flat is stable.
When my JT was stock it drove about as good as any vehicle I have ever owned. When and if you lift the jeep is when the real money begins to flow as you try to force a vehicle that is now setup for aggressive offroad work to behave demurely on the street. It is very doable but it takes some thought, patience and money. You should not have to worry about that on a stock vehicle.
Thanks so much for the quick response and the advice! It’s a 2024 Gladiator Sport S, completely stock for now, but I’m planning to throw on 285/75R17s soon. It drives fine overall, but it’s definitely a bit of a downgrade compared to what I’m coming from, which I’m okay with because, hey, I can take the roof and doors off! 😜
I’m really looking for upgrades I can make rather than repairs, since there’s no death wobble or major issues (it’s brand new with less than 5k miles). Just trying to tighten up the handling a bit before I put on the larger tires.
Thanks again for the help!
Caster - check caster.
I've yet to see "steering play" or wandering in a '21+ model year JT.
The tire pressure stuff is going to vary. You can't say "set psi to 35 and that will help" because that's going to vary with the tire size, construction and the weight of your vehicle. 35 may be good for some, not so good for others. I've frankly found no real difference between 33 psi and 36 psi on mine - except at the lower pressures the tires wear with that odd "low pressure" pattern on the outer treads. No one can give you a number and say "this will fix it" - all they can do is give starting points or things to try on pressure.
If your truck is stock, skip all of the add-ons like track bar and steering pitman brace - that's only going to have much effect if you have much larger tires.
Both of my JTs, a 2020 and my current 2022, have steered as well as any other truck I've ever had. No wandering, no looseness in the steering. Totally responsive. Move the steering wheel and the truck complies without hesitation.
Just give yourself some time to adapt the straight axle steering habits.
Which really, if all is right with alignment, tires, and so on, is no different than any other vehicle with a recirculating ball steering gear on a highway or street.
For street and highway, there is zero reason for a difference, unless comparing to a tighter steering ratio or rack and pinion (the norm these days)
Otherwise, these will have camber, toe, SAI, scrub radius and caster numbers like anything else. The solid axle has no impact on the street or highway - unless it's a logging road - because the geometry will be the same, with the same forces on the tires.
A lot of what people are detecting is a different steering ratio, or the comparison between recirculating ball sectors vs. rack and pinion.
IMO, the steering on the WK2s sucked big-time. Waay too sensitive. If you sneezed, you veered. The slightest twitch and you were all over the place. The JT is much more stable and fun/easier to drive.
It's not quite as good as my Silverado was - or was it? The big difference there was wheelbase, weight, height, and so on.
And over-tight is worse than slightly looser... it's a great way to wear out the gears.
That's not a torque value - that's play adjustment. People have no clue how those are made inside, and go in tightening things, taking out all play, the gear gets hot and suddenly you have more trouble.
That adjustment is meant to be done on a bench. You use a torque wrench to set preload on the worm shaft, then you adjust that "screw" until you reach yet another value.
I've seen more steering gears screwed up because people thought tighter is better and went too far.
Have you driven a solid front axle much? The JT rides especially truck like, such as the jostle that comes with hitting an unbalanced road defect.
The only negative effect of the solid axle is as you said - big bumps, pot holes and so on. On a decent highway, a decent street, it's no different than IFS with recirculating ball steering sector. Why would it be? The geometry is the same on a stable road.
The Grand Cherokee ZJ and WJ were solid front axle vehicles. My neighbor/friend drives a 49 Ford Coupe across the country - to the salt flats and with is T5 and build flat head engine, makes some pretty amazing speeds - solid front axle, king pins and all! (he does have AMC 10" front brakes on it thanks to my donation of parts to his vehicle)
I can show you a lot of vehicle that will safely and stably do well over 100 mph - with a solid front axle. We talk about, and look at pics and such of such vehicles at our Tuesday coffee group. One of them hit 200 mph on the flats - straight axle.
The big difference is on very uneven ground, washboard roads and the like.
That's when the swing of the axle doesn't match the swing of the tie rods and things get goofy.
When one studies the geometry of both types of suspension, takes a close look at the geometry and design, it's apparent, there's no reason for any difference on a decent road.
It's off-roading where it matters, or rough roads that toss the ends of the axle up and down a lot.
Belcher24256
Haysi VA
2022 Jeep Gladiator Rubicon Eco-Diesel
Police Officer
Pay attention to torque values for the two types of steering box, may save a HUGE headache.
I would be very careful with those type adjustments. I have personally seen two different vehicles a van and a ford truck where it was adjusted too tight to remove play and a short drive down the road and back ruptured the steering box forcing the recessed plate out the bottom of the gear housing. The problem with that is obvious, you lose all steering control.
