2022 gladiator aftermarket sound bar
Jose R
Jose
TX
2022 jeep gladiator
Tire tech
Hello guys im need to the forum and im currently looking to install a american sound bar 4 8 inch and 4 tweeters with my factory radio I have bought the factory amp bypass module amp pro AP4-CH42 and also the APH-CH03 adapter for factory amp to try and keep as much plug and play as possible my question is how do I wire the 4 speakers and 4 tweeters to the aftermarket 4 channel amp? Can I use jeeps factory sound bar plug or would I need to run each tower speakers to the voice amplifier
Any instructions included in the box?
Jose R
Jose
TX
2022 jeep gladiator
Tire tech
No sir no instructions just empty enclosure
GAJTR
Jon
Macon, GA
22 Jeep Gladiator Rubicon, 22 Jeep Wrangler JLU
If I remember correctly, the amp pro AP4 goes inline behind the radio and has 3 sets of RCA outputs. Run the RCAs to your aftermarket amp and then speaker level output from there to your replacement soundbar....if that's what you're asking.
joanny
ohio
2023 JL, 2023 Jeep 392, 2022 JT Rubicon
Realtor
If you're adding an aftermarket 4 channel amp, I'd run new speaker wire from the amp to the sound bar rather than relying on the factory sound bar wiring. It'll give you more flexibility and eliminate any questions about the factory wiring limits.
As for the tweeters, make sure they're using the proper crossover that's recommended for the setup. Don't wire the tweeters directly to the amp channels without some form of crossover protection.
How you wire the four 8s and four tweeters will depend on the impedance of each speaker and how your amp is rated. What amp are you using, and are the speakers 4 ohm or 8 ohm?
