Henson002098
AC will not work unless on Max AC. When turned to regular AC, very warm to hot air blows out of the vents, even when set at 65 deg, any help would be appreciated.
Mine has been like that except it will eventually work on regular after 5 minutes or so.Not sure what the deal is.AC will not work unless on Max AC. When turned to regular AC, very warm to hot air blows out of the vents, even when set at 65 deg, any help would be appreciated.
Exact same issue with mine. I have to drop it down to Max Ac in order for it to begin cooling. Otherwise, there is no change.I have the same issue. When it's set to 65 its warm/kinda hot but when I go down to max ac then back to 65 it blows semi cold.
