Door Hinge Bushings
Grover
Defender 90
Mechanic
Hello all!
I’m a proud owner of a 2025 Nighthawk.
Since I drove it home from the dealer I have been talking steps to keep it in good working order, rust proofing etc…
I removed the doors to lubricate the hinge shafts and noticed the shafts had a very rough texture which would wear out the bushings quickly.
With fine Scotch Brite pad, I smoothed out the shaft surface without going down to bare metal, coating them with white lithium grease and reassembled with anti seize.
If you take your doors off, it might be worth checking out…
Cheers…
D_JT
Travis
New Mexico
23 JT Rubi diesel, 19 JL Rubi, 00 TJ, 48 CJ2A
Its not an issue. I have a 2019 JL and the door hinge's work and feel just like new. But why did you use anti seize? Just remove the bolts and leave them off. Keep them in the storage bin under the seat.
