JSCAN and OEM LED Headlights/Halo settings...grrrrr
RedChili
Southwest
2022 Gladiator Rubicon
So a while back I replaced OEM halogen headlamps with a set of Mopar OEM LED's. I have a 2022 and the wiring was an easy plug into the existing harness with no additional splicing or adding or taking away pins or anything like that. Ended up getting a Tazer Mini and had them running within 5 minutes. Halos worked, high beams low beams worked, the whole 9 yards. The Tazer menu was straight forward, if a little clunky.
So I read through a few threads and someone somewhere mentioned a concern about the security gateway module and network security and how leaving a Tazer plugged in could compromise that security. None of the things I used the Tazer for, required that I keep it plugged in (tire size, LED's), but I kept it plugged in anyway. So thinking about the security issues (or likely non-issues) and the plan to take the gladiator into the dealer for an oil change, compelled me to tinker a bit and try out Jscan. I purchased the security bypass harness, and an OBDLink MX+ and decided to tinker. They arrinve a week or so ago and today seemed like a good day to tinker, so I unmarried my tazer which reset the factory settings, and started to mess with the Jscan App.
Initally after the unmarry, as expected, the LED's weren't working, so I started to try and set them up. First I entered the LED light settings menu under the "adaptations" section. Seemed straight forward and I enabled low beams and high beams. So far so good. Seem to change quite quickly and those were working in quick order, but no halo's. No big deal I'm sure there was a solution. I quickly looked online for some guidance which led me to the DRL setting menu under the adaptions section. This is where the frustrations started.
First, any time I attempted to change a setting, the app would lose connection with the Obdlink. So I'd have to disconnect the OBDlink and close the Jscan app for 30 seconds and try again. Then if and when I managed to change a setting, I could only make one change before the app disconnected again forcing another shutdown and delay. This happened over and over again. Every so often I'd get lucky and would be able to change multiple settings without running into a connection issue, but that wouldn't last too long.
In case you are wondering why I had to make so many changes? Its because, at least to me, the menu selections and items are confusing. All I wanted to do was to turn on the halos. So read online (forums and JSCAN help pages) and changed DRL configuration, Daytime running lamps present...but then there is also an LED Dedicated DRL Present setting...which should be used? I still have no clue! Then there are the Left Dedicated DRL lamp output present setting...and the Right Dedicated DRL Lamp Output Present Setting. And then I switched back to the LED light section and messed with settings for CHMSL Lamp Present on/off setting and the Quad Headlamps Enable On/Off setting. Still not working.
So then I go back to the DRL menu and back to google and someone somewhere mentions the "Signature Lamps or Mirror Repeater Present - Pin A5 & Pin A7 (Halo)" setting, and the "Signature Light Present Present On/Off" settings...but this wouldn't apply to me right? I mean I didn't have to mess with any pins because my lamps plugged right into existing harness without issue and I didn't have to mess with any pins. So just before getting ready to throw the OBDlink into the trash and pull back out the tazer, I gave those settings a try and swapped them to "present" and viola! The dumb halos started working.
I am dense, I'll be the first to admit. When it comes to some things I need clear instructions beating me over the head. I can follow clear instructions (most of the time), but I did not "see" how a setting called "Signature Lamps or Mirror Repeater Present - Pin A5 & A7 (Halo)" and or "Signature Light Present Present On/Off" would be the "turn on the halo" settings...yes I know it says Halo at the end of one of the settings, but I only saw "pins" and thought, nope, must not apply to my situation. Silly me.
So, even at this point, I still have no idea which exact settings one needs to add OEM LED headlights with operational halo DRLs using JSCAN. I'm assuming the last two setting were likely all that needed to be set up, but I could not confirm it because my dumb ODBlink and App would only cooperate for a minute or so at a time or a single setting at a time, making the entire process a giant PITA. I may have figured it out much faster, but having to disconnect and restart the app so many times, made for a much longer afternoon than anticipated.
I'm sure there is a proper explanation for all of the settings in the Jscan App. I could and should have probably planned it out better with more research on which settings I should use, but the lost connections and restarts were the real time killer. Not sure if it was the App or the OBDlink...when they worked they made quick changes, but when they dropped connection, what a headache!
Drexx
Brick, NJ
2020 Gladiator Sport
IT
This was the clue I needed to get mine working. Thanks. They seem pretty bright. I need to compare to a factory Jeep.
They are controlled by pins 5 & 7 in the A1 plug so even if it is factory wiring it is still 5 & 7.
I had the same issue with Jscan and OBDLink until I realized I didn't need their app. Just connect in Settings/Bluetooth and only use Jscan and it works fine. The two apps compete fro the adapter.
ecidiego
San Diego
2021 Gladiator Mojave
IT
This applies to every truck with OEM LEDs and the harness present. It is telling the BCM you have the lights and to use them.
He's likely talking about the BT adapter, not the software . OBDLINK MX+ is the adapter.
He's certainly not run both apps at the same time!
Sounds like the initial issues were bluetooth issues - time to restart the phone and make sure it can keep a BT connection to the OBDLink adapter (he's using their adapter, not their app)
This is what I set for OEM headlights with AlfaOBD. JSCAN macros stuff, so who knows what it does/doesn't turn on.
OEM LED Headlights:
CBC Features: LED Low Beam Lamps Present: Yes
CBC Features: LED High Beam Lamps Present: Yes
CBC Features: Quad Headlamps Enable: Yes
CBC Extern.Light Calibr.: Dual Filament Headlamp: No
CBC Config I/O Usage: Signature Lamps or Mirror Repeater Present - Pin A5 & Pin A7: Signature Lamp
CBC Extern.Light Calibr.: Signature Light Present: Yes
Macros stuff?
Not with what I've done - I go to each line and make the change.
i know tazer does the macro thing - if you want to make a change that requires 4 line changes, it does those for you with one setting change.
Go to the JSCAN facebook page, mention what you are doing. Many dozens of Jeep people there have done this exact thing. If it's a problem they can't answer, you can send the JSCAN guy a facebook message and he usually responds best that way.
Drexx
Brick, NJ
IT
Yes and as per the MX+ instructions I started their APP and JScan and had exactly the same issue.
jav_eee
Wonder how many people have had their jeeps hacked after leaving the Tazer in place...
mike_op
Michael
Hawai’i
Gladiator Mojave
OEM LED Headlights:
Aloha,
Could you explain why “quad headlamps enable: yes” and “CBC Extern.Light Calibr.: Dual Filament Headlamp: No”.
Thanks ??
ecidiego
San Diego
IT
Aloha,
Thanks ??
I believe quad means you can have high and low beams on at the same time. Whenever I would turn on my high beams with halogen, the low would turn off. The LED can have both on.
The halogen bulbs are dual filament. LED has no such concept.
