OEM LED woes (no halo jumper installed)
RobbertCole
Rob
Madison WI
2020 Jeep Gladiator, 1997 Mustang GT
2020 gladiator sport
Led headlights; installed
OEMLED halos Jumper Wiring -Mopar 68347117AB: installed
Tazer: updated to latest firmware
Settings in the jeep halos and LED headlights: Yes & yes
No halos
What might I be missing?
Klicht87
Connecticut
2022 Jeep Gladiator Willys
Veteran/DoD Program Analyst
I don't believe the halo wire was installed on the non-led models for that year. I believe it was in all models starting late 21/early 22. There's a procedure to run it to the BCM but I personally don't think it's worth the hassle. I have oracles and the halo used a fuse tap to the fuse box under the hood. I used the fuse 52 slot, I believe. That slot is for the wireless speaker that I don't have and it has power on when the vehicle is on which means your halos will always be one. Hope that helps
ORACLE Terry
Peak Sponsor (Level 2)
Terry
New Orleans, LA
www.oraclelights.com
The installation video shows the process if you need to run a line to the fuse box for the DRL halos. It's around the 2:00 mark. If you don't have an add a fuse from your kit, they are easy to obtain.
https://www.oraclelights.com/products/oculus-bi-led
