TPMS Pressure Sensor Issue
DanW
Brownsburg, Indiana
So I had a tire pressure sensor fail on my JT. It was on the right rear at the time and was not registering pressure, triggering a ¨Service TPMS¨ message. I took it to get the tires rotated and balanced @Discount Tire. They changed it and rotated the tire/wheel to the right front. Unfortunately, it is still not registering. I took it back today and they scanned it and found it was transmitting and they went through the activation procedure again. I drove 30 minutes home on the highway and it still is not registering.
I know it is not the sensor because it has shown zip in two different locations and when it was rotated to the spare, all 4 wheel positions were registering.
So maybe there is a compatibility issue? They did say the original, which was not registering, showed a good battery. I am not sure if they checked if it was transmitting or if they could even do that.
So I´m stumped at this point. The only things I can think of are that it either the new one is defective, or maybe it is not compatible. Because the sensors pick up the other tires at all 4 positions, I think that rules out a problem on the receiver end.
So I´m wondering if I should have them replace it to see if it is a bad unit, or if I should buy a Mopar OEM sensor and have them install it.
Has anyone else had a similar issue, and if so, what was the solution?
Any suggestions will be deeply appreciated.
DanW
DanW
Brownsburg, Indiana
I see what could be a problem. There are two part numbers for the 2021 JT. One is for trucks built before 6/8/21 and another for those built 6/8/21 or after.
I think I am going to go to the dealership and get the right one and then have @Discount Tire throw it in there and see what happens.
swtrailboss
Travis
21 Gladiator Mojave
Auto tech
If the sensor problem is following the location of the tire after rotate then id say safe assumption would be a sensor compatibility." They all look alike but are not the same"
DanW
DanW
Brownsburg, Indiana
Heading to the parts department this morning. I´ll post up early next week when it gets installed.
DanW
DanW
Brownsburg, Indiana
Got the new sensor. @Discount Tire getting it installed.
I should've lubed up before going to the dealership. $81.
