Are there any check engine or warning lights when we eliminate the FAD and put in a 1 piece passenger side axle??
Uparms
RedBearon
Josh
Tampa, FL
2021 Jeep Gladiator Rubicon
If you remove the FAD module, yes.
Some one-piece shafts do not require the removal of the FAD (it just doesn’t do anything after the ring is eliminated) and others do require the removal of the module.
RCV’s do not require the removal of the FAD. Most ujoint style shaft do.
Either way, it’s easy to electronically eliminate with JScan or a Tazer.
hjdca
Southern California Mountains
Note: some guys have reported slight vibration when removing the FAD with a lift kit. The additional parts free-wheeling, but, rotating at an angle is the culprit.
