How Long Should it Take For Sway Bar to Disconnect?
Troybilt
Troy
Ohio
troynemitz.smugmug.com
2020 JTR
Parks Operations
I was trying to get my sway bar to disconnect and I may not be doing it right. How long should it take to fully disconnect?
I was in 4H in park in my driveway pushed the button and waited over a min. The sway bar light just kept blinking. I put it in drive and pulled up a bit and that had no effect. Pushed the button again and it read sway bar connected in like 2 sec. I tried again and let the sway bar light blink for 3 min or so and still nothing.
Am I missing something? I plan on doing Peters Mill Run next weekend to get my 1st Jeep Badge.
Jolly’s Jp
Wendell NC
JT Rubicon LE
the sway bar will only disconnect in 4lo without some sort of programmer. When in 4lo and on level ground, should take no more than 5-10 seconds.
Troybilt
Troybilt
Troy
Ohio
2020 JTR
Parks Operations
Don't post if you don't know what you are talking about. You let everyone know what a fool you are.
Troybilt
Troybilt
Troy
Ohio
2020 JTR
Parks Operations
Jolly’s Jp
Wendell NC
JT Rubicon LE
No worries mate. Just remember its better to spend your time learning something new than teaching something not known.
it is also best to treat people with respect and not talk down to them. Like I said, I crossed my channels and admitted it. Guess some people never make mistakes. I’m out!
3-pedal-Rub
Joe
Salem, Oregon
Harley Night Train, Buell Lightning, TL, 4runner, JTR
Try getting out onto a flat road at standstill.
Renegade
Zac
Signal Mountain, TN
2020 JT
The swaybar may not be able to disconnect if it is in a bind. Disconnecting while moving may work better. The coupler has to move.
MaximusJTRubi
Houston
2020 JT Rubi
always disconnect mine while driving slowly. Turning gently. only takes a second or 2 every time.
jrf
J.R.
PA
2020 Jeep Gladiator Rubicon Launch Edition (White), 2001 TJ Sahara (white)
Another trick that works, hit the button then step out of the Jeep, grab the roof or roll bar just above your head and rock the jeep back and forth. It helps to "unbind" the swaybar. I know no one wants to get out of the Jeep but I've found this to be the easiest way when parked and not moving.
