Mateik
Hi Guys
I have a 2023 3.0 Diesel Gladiator that will not power up. It have maybe 100 miles on it.
the case is that I were to install a wiring harnes for my trailer hitch. I removed the negative connector on the main battery and installed the wire on the positive on the end of the fusebox. Installed the negative connection on the battery again.
When I now try to start the car it does nothing. The center display is on, and says press brake to start, or what ever. But the ignition does not turn on and the car refuses to start. The stereo only turns on with the logo, and then turns off again. This happens continuously.
Also worth mentioning is that the key fob does not work on the doors.
We have checked all fuses and both the main and auxiliary battery is 12,7volts. Disconnected the aux battery as well
Anyone have any suggestions??
