JTenn
- First Name
- Jason
- Feb 21, 2022
- 47
- 824
- 1,601
- Middle Tennessee
- 20 JT Overland, 21 JT Willys
- Occupation
- Mechanical Engineer
My wife has a 26 Wrangler Rubicon X with 4600 miles on the clock. Since new, the vacuum leaks off within 2 minutes of shut down. I've tracked the vacuum leak to the brake booster. I have taken it to the dealer, which did not surprise me when they said nothing wrong. All tests show no vacuum loss or codes. I feel certain they are plugged into the obd with the engine running and monitoring the reported electronic vacuum data, which clearly shows vacuum present since the vac pump is running. So I did my own testing between my JT and her JL. I realize they use different boosters but the operation is identical. I disconnected the vacuum union in front of the booster and pulled a vacuum on the booster side. The JT, holds vacuum, the JL does not. I can't get it to even move the gauge. There's clearly a split or non seated diaphragm in the booster. How do I get the service department to understand this without sounding like a know it all prick. Unfortunately most techs lack basic troubleshooting skills and are performing scripted tasks straight out of a book. I made it clear the issue is not during normal operation. The issue is having to stand on a brick pedal (see what i did there) to start the Jeep. The brakes currently work fine but there has to be a pin hole leak in the diaphragm. It's aggravating that I have to wait until a major malfunction to get a warrantied part replaced. Does anyone know if a brake booster is serviceable or are they permanently sealed? My JT has to sit for 3 weeks before the vacuum leaks off enough for the hard brake pedal.
