JSCAN engine fan function vs. tazer "cooldown" feature
I would hunt down that fan controller and see if you could make that work. I looked at it once, and they sell several versions of it.
$325 for the one that gets talked about in the JL and JT forums....naw, thanks, but no. Definitely not worth that much for a little bit of time for only a handful of drives/days in the winter. (I looked for links and references in the JL/Wrangler side, and in these forums here)
Thanks, but........... For $325, I'll keep tapping the fan icon in JSCAN, or go Tazer Lite to turn the fan on. No wiring, no messing around.
BillyP
Billy
2021 Gladiator Mojave, 2004 Wrangler Rubicon
Have a bracket made behind the plow that you can attach a light weight aluminum duct to catch and direct air to the front/grill while you’re driving highway speeds. When you’re going slow while plowing take it off. It should work for any vehicle you attach the plow to. Easy enough.
