New LED Headlights and DRL Problems
mclousing
Delafield WI
Jeep Gladiator Mojave
ok people, I have a gladiator mojave with the dreaded halogen headlights. I decided to change it to LED. I got OVSAuto LED with Halo headlights Link Here, and AuxBeam 4 Inch fog lights Link Here. Individually everything works fine, however, when I have both DRL Halo's hooked up, the DRL will light up for a few seconds and turn off. It would do that 3 times in a row and then just leave the DRL's off. It seems to be a power draw issue. Looking to see what is the suggestion for this. Right now I am just unplugging the DRL Halo on the fog lights.
Can you run just the DRL lights?
JRobes
South Dakota
Enginerd
I'd imagine you'll need to get a programmer to change the vehicle computer settings from halogen to LED. The vehicle computers monitor the electrical circuits to each vehicle light, and if it senses something out of the normal range, it'll disable them or you may see flickering issues.
mclousing
mclousing
Delafield WI
I can run just drl if I only do the OEM fender drl and at most 1 of the two halos (headlight/foglight)
djthumper
Larry
I.T.
Reprogram to LED. I have the same headlights. Also, where did you tap the for the Halos on the fog lights?
mclousing
mclousing
Delafield WI
I tapped in both halos into the side fender harness
