Problems with low beam
bobbybog
Bobby
Buying a 2023 Gladiator Sport
I have a 2020 gladiator sport S, that is having some issues with the passenger side low beam. I thought the bulb was bad so I replaced it, but that had no effect. It just randomly stopped working and now we’re not coming on at all. The hobby works fine and the driver side low beam and high beam work fine. I have tried multiple bulbs so I know the bulb is good.
I will say that the first time it went out the next day it worked fine, then it went out and back on again for a little while. Now the low beam does not work at all, no matter what I do. I checked the connectors and wiring everything seems to look OK. Any good ideas?
bobbybog
Bobby
Anyone have any ideas on what to check next? Probably worth noting that my drivers side flasher in the front doesn’t flash either, even with a new bulb. Parking light is fine, just doesn’t flash either passenger side flasher works, but parking light does not.
all kinds of gremlins. Could this be a ground issue?
JeepCares
JeepCares
Auburn Hills, MI
Jeep Family
Customer Care
Hi there! We sent you a PM that you can reply to if you would like our assistance with this.
Yenori
Jeep Cares
