Moose95
I'd appreciate if anyone with any experience with the fuel skidplate could provide some advice... or recommend a shop in the Northern Virginia area.
I purchased the aluminum engine, transfer case, and fuel tank skip plates from Quadratec, and installed the engine/trans and transfer case plates today without a hitch - they went on great, and seem to be sturdy. However, I had seen some installation videos of the fuel tank skidplate for the Wrangler, and several of them said it was really difficult to line up everything. I took out one screw from the existing skidplate to see how it would go, and the hole for the skidplate immediately shifted a quarter inch, making it impossible to put the screw back in.
I have basic handyman skills, enough to install simple mods, but I do not have a shop or sophisticated tools, and now I am concerned about going any further. The instructions say to remove almost all the bolts in order to bolt the new skidplate on top of the existing one, so now I wonder if the one bolt hole shifted because I didn't loosen all of them, and if this is normal for installing this item.
So, at this point I either go "all in" tomorrow and loosen the rest of the bolts and then try to put it all back together, or I try to find a professional shop to do the installation. Has anyone installed this fuel tank skidplate on their Gladiator? The only installation videos I can find on youtube are for the Wrangler, which is similar, but not identical. Thanks!
