- First Name
- Bill
- Oct 12, 2019
- 247
- 40,493
- 54,056
- Runnells, Iowa
- Occupation
- Vehicle Showcase
- 3
What makes you think those numbers are bad?
Timing is controlled by the ecu on an "as needed" basis - unlike the old school systems where it was purely RPM-based with vacuum advance determining timing based on load.
10 degrees isn't out of the realm of reality at idle. Likely you'd never see it advanced more than that at idle because the engine running slowly the burn has time to progress in the cylinder and give peak pressures at ~ 14 to 16 ATDC.
The PCM determines timing based on several factors including intake air pressure, intake air temperature, engine temperature, EGR can come into play.
I noticed my wife's GC was at -2.00 degrees at idle multiple times. That's a bit retarded but again, not out of what I've seen over the years in older engines so it likely had a reason.
