Replace manual door panels with automatic panels and door locks are not working
jeep1
Wayne
Chilliwack, BC
2020 JLUR, 2024 JLURX
Again sorry, I had the interior carrier panels installed and the doors panels only. There anybody who has pictures of what I need
Ok... let's start with the basics ? What year of Gladiator do you have ? Have you confirmed you have all the body wiring ? Some Gladiators do, some don't..... Check where the door harness is connected to the body.
You said you have had all the door harnesses replaced. If so then you should the same number of wires on both sides of the connector "2" shown in the picture below.
Jeep Gladiator Replace manual door panels with automatic panels and door locks are not working Screen-Shot-2018-10-08-at-9.28.00-AM-300x262
IF you have the wiring, the locks are relatively easy. Windows... entirely different story I haven't puzzled through.
For the locks ... Did you have the latches replaced ? If not, you need the following:
https://parts.allmoparparts.com/oem-parts/mopar-front-door-latch-left-68456863aa
https://parts.allmoparparts.com/oem-parts/mopar-front-door-latch-right-68282954ab
https://parts.allmoparparts.com/oem-parts/mopar-wrangler-jl-left-rear-power-lock-latch-68282961aa
https://parts.allmoparparts.com/oem-parts/mopar-wrangler-jl-right-rear-power-lock-latch-68282960aa
Once that's done, you need to use something like JSCAN or AlphaOBD and program the BCM so it knows you have power locks. Again... lots of instructions for that kicking around including a few posts up from this.
Windows ...
Do you have the window up/down switches in the middle of the dash ? Do you know if if the wiring harness is there ?
If you don't have the wires at the door, and/or don't have the window wiring harness in the dash then this just got MUCH harder. You are adding pins to all the plugs, running wires back to the BCM etc....
BGlad
NJ
2022 Gladiator
You need this to make it work. This will work on a sport for sure. I am still going to have it done on mine eventually
https://www.a1electric.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=JE-JL-LK4
I installed these on my base sport. The front doors were not bad. I still haven’t done the back doors cause I’m having difficulty getting the inner door panel off and i feel like I’m gonna break something. I might bring it to a shop to do the rear doors. The wiring was easy, just time consuming. I was fortunate to have the AUX switches option so i had the extra wiring loom in the front passenger compartment. But the front doors work flawlessly and am very happy with the kit, especially at that price. It’s a bargain. I might give the rear doors another go in the spring. But for now i can definitely recommend the A-1 kit.
