Will 17x8.5 rim and 5.22 offset lead to more steering wander than stock rims with the 284 70 R17 tires?
jmdusza01
Maryland
2021 Jeep Gladiator Overland
RN
Just replaced stock rubicon rims with quadratec 1941s. Look awesome. My question is would the 17x8.5 rim and 5.22 offset lead to more wander than stock rims with the 284 70 R17 tires? I have also aired down to 33. They of course inflated to 38 for tms sensors with install
Jeeperjamie
Jamie
Kannapolis nc
2020 jeep gladiator
Weyerhaeuser
It should wander less from my experience. A wider stance should give you more stability and a little better cornering, or at least that's how mine feels and my JKU felt with a wider stance.
Captain Muskie
Shaun
Upstate Ny
2020 Gladiator 2019 JLUS
Steelworker
I just went 9 inch wide rims with 5.25 backspace on 285 70 17 ko2 drives great once i aired down to 32 psi
Renegade
Zac
Signal Mountain, TN
2020 JT
OP- In theory, the scrub radius from the new wheels could create more road force into the steering components, and cause some adverse reactions. In reality, you haven't changed it that much, and you should be fine. I've been running the same spec wheel as you for over 20k miles, and it drives just fine.
jmdusza01
jmdusza01
Maryland
RN
Thank you. Was my thought and will verify with chalk test
