12V "Ignition On" power for rear view camera
steven1955
Manheim, PA
2007 V8 4Runner, 2016 Mustang Convertible
Is there an existing source of 12V "Ignition On" power in the rear of the truck bed I could tap in to to power a rear view camera that would mount on top of a bed cap?
Secondary question: If there is such a power source, is there a commercially available connector I can buy so I can insert the connector to access this power?
I prefer to not cut into the factory harness.
I am willing to run an all new wire if I have to, but why do that for a low power device like a camera if there's something I can easily tap in to.
There's a hot wire in the tow wiring. You could try one of the Curt T harnesses that connects between the factory plug and the bumper connector.
steven1955
steven1955
Manheim, PA
Yes, there is a wire that is always hot in the tow wiring, and I plan to use to power the interior lights in our Alu-Cab. Those lights have their own switches.
What I need is a wire that is hot only when the truck is in RUN mode, and off when the truck is in OFF mode. I also prefer this wire to be off when the truck is in ACC mode, but that is less critical. I just want my future rear view camera to turn off when I turn off the truck.
Mojave20
2020 Mojave
You can use the harness below to tap into your cigarette plug without splicing your factory harness. You’ll just have to run a wire to the back. Hot on ACC & run. I used this for running my windshield camera power.
https://a.co/d/ccGlDPy
For that, you'll have to run a wire from the front to back.
fourfa
CA
22 JTRD + ACCC
I wonder if there’s switched power on the fuel pump harness
Free2roam
Robert
I ran an extension wire from my fuse box all the way back. Used to have a picture of the setup and I think I posted about it somewhere but can't seem to find it. I wouldn't be able to get you a definitive answer till later this month. I did buy piggyback fuse set-up from Amazon and the worked perfect.
