2022 Overland Kill Switch on Fuel Pump K02 or Starter Relay K03 in Fuse Block
Cspence
CT
23 JTM
I would be interested in one of those. Im assuming the start button pulls out without too much issue
Did you ever get this tee harness? How did it work out?
mrmo
Mrmo
East Tn
2022 Gladiator
nuke
yes, direct plug in, then installed hidden switch into the circuit, works fine. locating a suitable spot for the switch was a challenge
RJWHD95
RICK
FL
2022 GLADIATOR OVERLAND
Easiest is a kill switch on the red wire of the connector for the push to start button. That way you can still remote start the vehicle (if equipped), but the ignition can’t be put in run to drive the vehicle.
If you want it plug n play so you don’t have to cut/tap/splice any factory wiring, I can set you up with a Tee harness for a switch.
dayusmc
Jersey Shore
Retired Marine
If you have a Tazer, the easiest way is to make a harness for it and hide it elsewhere in the truck. You then can use the pin feature and no one can steal the truck. I did it, works great .
James H
Jim
Fulshear TX
2021 Gladiator Mojave
Jack of all tirades
Was this an Amazon purchase? Will you share a link to the tee harness please?
Cspence
CT
23 JTM
I plan on doing this as well. I'm a little spooked with all the recent noise on thefts lately.
dayusmc
Jersey Shore
Retired Marine
The street I live was hit and one of my neighbors Jeep was stolen. After that I was frantic to do something to keep my jeep from getting stolen. I was able to make a harness to relocate my tazer with thanks to Jimmy07's help. Best thing about using the Tazer's pin lock is that it works with aftermarket and OEM remote starts. With using the pin lock feature instead of hiding a switch to kill the jeep, no one will ever be able to see you flip the switch...
There is a thread I have on it, but I really should make a dedicated thread with it and the other options, I will try to do that today, time has just been tight.
RJWHD95
RICK
FL
Jimmy i would like a harness.
