8 Speed Tuning Tool for HP Tuners
bmpcamry09
Brad
IL
2025 JLU 3.6
To any fellow tuning nerds out there, or anyone who has HP Tuners and wants to learn DIY and wants to have a better understanding of shift scheduling in their 8 speed, I have spent the last few weeks creating a tool in Microsoft Excel that I wanted to share with the forum.
The way these transmissions are set up to shift is based on "OSS" or output shaft speed. Bascially, it means your drive shaft speed. Transmission tuning in this is not based on MPH like on GM stuff. In tuning a bunch of these, I came to realize I could not use the same generic shift scheduling across different customers because due to gear size and tire size, actual MPH and RPM varied greatly. To make the tuning easier for me, I created this excel tool to give my customers a truely customizeable experience in regards to how their shifting is set up.
If you want to use your shift schedules located in your HP Tuners read and get a visual and meaningful representation of what the numbers mean, simply copy them into the correct table in this tool. Make sure you enter in your gear ratio, tire diameter, and tire revs/mile in order to get accurate data. You can then tweak your tables to the RPM/MPH you want using the tool.
As an add on, just know that on nearly every 8 speed I have tuned, even on other makes and models, aggression table #5 is the one that is used the most in normal driving situations.
Enjoy! And as always, hit me up if you want your JL or JT tuned.
BlueScapegoat
Trevor
MN
91 ST185, 04 Ram SRT10, 04 Forester XT, SC'd 05 Rubi, 22 JTRD
Air Traffic Controller
I've never plugged into a tuned a vehicle this modern (with HP tuners) but I have an MPVI2 and I've tuned my 04 Ram SRT10 and 05 TJ Wrangler pretty extensively so I'm somewhat familiar with the interface. They're both manual transmissions though. I have absolutely no experience with an auto.
So I'm not going to sit here and ask you to explain it all to me but I'm not sure where to enter the info you're talking about into the spreadsheet, and additionally, those numbers across the top appear to be the gear ratios and isn't the trans in our Jeeps an 8HP75?
The ratios you have listed are more closely aligned to an 8HP70, I thought.
My info could be wrong. Anyway, looks like a cool resource I just need to get my head around it.
::edit::
I see the fields to fill in now, just blind is all
bmpcamry09
bmpcamry09
Brad
IL
2025 JLU 3.6
Yep it’s all there. 850RE is what I see the most so that’s the default ratios but you can modify them to whatever you want
