Determining tension of parking brake cable?
Aleph
Alaska
2023 Gladiator Mojave
I tightened up my parking brake tensioner under the center console so now my brake works again.
How can I tell if I’ve put too much tension on the cable? I don’t want to be driving around having the drum brakes engaged with the parking brake lever all the way down. I tightened it then backed off a bit.
Should I just ensure there’s a tiny bit of slack when the lever is disengaged or is it just a guessing game?
I suppose to be really sure I’d need to get the truck up on jack stands (which I don’t have), spin the wheels manually and check for brake drag. But was wondering if there’s an easier way.
Aleph
Aleph
Alaska
I guess I answered my own question. Just ensure there’s a small amount of slack when the lever is disengaged.
Vtur
Le
Norcal
JTOD
Electrical Foreman
The correct way to adjust them is via the brake shoe star adjuster. Turn it until it has a little friction then turn back 3 clicks. Do that on both sides.
PuddleJumper
Cortlund
Alexandria, Virginia
23' JTM, 22' JTR, 22' F56S,
this. i stretched my cable doing the console way the first 2 times.
Aleph
Aleph
Alaska
I’m guessing I’ll need to put it on jack stands to adjust using the star adjuster right?
It's a lot like adjusting the shoe brakes of the past - ideally, you have the tires off the ground, adjust until there's some drag, then back off until no drag or a couple of clicks.
THEN you adjust the cable.
Adjust the shoe clearances first, then adjust the cable. (cables do stretch even in normal use)
Can do it one side at a time with a regular jack.
Yeah, I'm used to the limited slip that doesn't allow you to turn only one wheel at a time. Must have both off the floor and transmission in neutral to turn the wheels for brake adjustment.
These aren't that way.
