Electrical Help Needed!
Cattywumpuss
Paul
Anchorage, AK
2026 Jeep Gladiator Sport S
Ok, need help from those more electrically inclined than me. I’m curious about thoughts on installing the below 12V “socket bank”.
I like that it has a master power switch and an inline fuse as well. Looks like it is designed to be connected directly to the battery.
My question is would connecting it directly to the battery (Positive) and a grounding bolt be a good idea or not? I can see running the wires through the passenger firewall for that.
Or would there be a way to connect it to the AUX switches wiring harness and not even have to go through the firewall?
I’m just not sure what is and isn’t a good idea electrics wise. Thanks in advance for any help / feedback! Product pics below.
Jeep Gladiator Electrical Help Needed! IMG_0114
Jeep Gladiator Electrical Help Needed! IMG_0115
Jeep Gladiator Electrical Help Needed! IMG_0116
Jeep Gladiator Electrical Help Needed! IMG_0118
Jeep Gladiator Electrical Help Needed! IMG_0117
Neomonk21
Travis
PA
2023 JT Mojave
If I was installing it I would use an Aux switch. I try not to connect directly to the battery because it could have a very small draw that could drain your battery. I wouldn't trust their on/off switch. You could test it to see if it does draw any power when it's switched off. The Aux switch would give more peace of mind, though.
JTdiRtyD
Wes
MN
'22 JTRD
Army vet, low-code dev
With how many ports this thing has, I'm surprised its only a 15a fuse.
Anyways, running it straight to the battery is not a good idea. Should you forget to shut the power off you could end up killing your battery.
You factory AUX wire harness has an ACC wire tucked away in the passenger footwell (not a wire for a switch, but an actual ACC wire). This is probably your best bet as you wouldn't need to waste an AUX switch for something that already has a on/off switch.
Bandit’s Lair
Southern California
2021 Gladiator Sport S
Second the Aux switch. Are there going to be permanent devices on it? If so I’d hide it as well. Leave it in the “on” position and tuck it back up under some panels. I’d like to do similiar and have a barrel plug bank that is pretty much just a “trip” source for fridge gps things like that but only needs to be on when on a trip.
Cattywumpuss
Cattywumpuss
Paul
Anchorage, AK
Ok, that’s what I was thinking too and why I asked about the AUX switches. Thank you for the reply.
Cattywumpuss
Cattywumpuss
Paul
Anchorage, AK
Thank you. I was aware of the 2 extra wires with the AUX switch bundle and was wondering about connecting to one of those like the ACC one. So appreciate the same train of thought and confirmation.
I was also wondering about the 15a fuse with all the outlets on it. 🤔
Cattywumpuss
Cattywumpuss
Paul
Anchorage, AK
Thank you for the feedback. I wasn’t sure about the “permanent devices” yet and so wasn’t too sure how hidden away I wanted it. Their video shows it coming with sticky pads to “mount” it to the side of your center console or some such. But tucking it back under some panels is an idea as well.
I did think about tucking it on the passenger side of the center console, towards the firewall so that it was sort of hidden away but also accessible.
Food for thought for sure. I’m still leery about doing any “electrical” work (prefer the mechanical stuff) but know I have to dive in sometime and this seemed like a fairly straightforward wiring job. At least in my mind.
Bandit’s Lair
Southern California
It shouldn’t be too bad. As soon as you get a working knowledge of power-ground-signal it all becomes very clear in your head. Especially when they’re all 1 unit and used in conjunction. Drawings help a LOT.
EZRider
Arkansas
2022 Gladiator Rubicon Diesel
I was not aware of an ACC wire in the passenger footwell. Where is it in the footwell? What gauge and color wire?
Bayrat
DA
Florida and NYS
2023 HEMI Rubicon-2025 Gladiator Mojave
Fireman and Utilitiesman
I have one of those except I ordered with the aux cigar lighter for a connection as I have that in my truck up front. When I travel, I use it, but unplug the thing for the night as I do not trust it. If you wire via a switch, as mentioned, turn it off when not needed to protect from fire etc.
Cattywumpuss
Cattywumpuss
Paul
Anchorage, AK
Thank you, will do. I don’t fully trust them either so like the idea of having it switched to the AUX switches which I do trust.
sawman
Louisiana
2020 Gladiator Sport
Or use the Aux switch to control a relay which then feeds the socket bank, which could be connected directly to the battery. Several relays out there that could handle 20 amps plus.
Cattywumpuss
Cattywumpuss
Paul
Anchorage, AK
The socket bank I’m looking at using has a 15 Amp inline fuse although the AUX switches are also fused, with 15 or 40 Amp fuses depending on what I connect to.
Any issues with connecting multiple fused wires together?
sawman
Louisiana
Keep them separated. The fuses are rated for the equipment they are protecting. If you draw more than 15 amps with your socket bank, the magic smoke might escape. Not saying it will, but I would err on the side of caution, especially if it's an inexpensive Chinese product.
If you need more juice, put another bank on a separate fused circuit.
ETA: I personally wouldn't draw more than 15 thru any of those style sockets. If that much is needed, I would switch to a totally different connection. Something rated for the current draw expected, plus 10% for cushion.
ETA #2: After re-reading your post, you may have been asking about connecting them in series, ie. the aux wire (fused at whatever) feeding the bank wire(fused at 15A)? If so, that's OK as the limit for the entire run will be 15A (the lowest rated fuse in the chain).
Connecting them in parallel is NOT OK. (Multiple runs with separate fuses feeding one common load)
