Heated Seat Problem Fixed
shockerracing
Chicago, IL
2018 @MojitoJeep JL & 2020 @NeonGladiatorJT
I hope you guys don't mind that I am sharing this here, I shared it to the JL forums as this heated seat issue seems to be becoming more of an issue as the JL's are a little older, but I also have the same seats in my Gladiator and thought this may be helpful info for the JT community as well.
Our 2018 Jeep Wrangler JL started having problems with the OEM Heated Seats where it would intermittently turn itself off. The amount of time it would stay on was completely random from time to time so I started doing some research and thanks to @Rhinebeck01 he helped me figure out that the fix was to replace the cushion and back heated seat pads with new Mopar pads. I made a video of the process to share with you all so you can see how to open up the seat and replace the pads yourself. This isn't the easiest DIY, but if you pick up some Hog Ring Pliers and a bunch of Hog Rings it's very doable.
Outback_Joe
Joe
Oregon Outback
2022 Jeep Gladiator
Retired Civil Engineer
Thanks for doing the video. Bookmarked for future reference. With luck I won't have to use it. But the way things are?
