- First Name
- Bill
- Oct 12, 2019
- 247
- 40,500
- 54,021
- Runnells, Iowa
- Occupation
- Vehicle Showcase
- 3
Tire size, etc. should work, but it totally prevented me from doing some diagnostics on my 2022.I am pretty sure in AlphaOBD when it detects a VIN/PCM that is out of range, it gives you a warning, but lets you bypass and continue. I had to do this with my 2022 while waiting on the software updates to recalibrate my tires/speedo.
JSCAN likely can also do the tire size calibration and gear ratio changes.
It will change other things as well - shift points, etc. as things are based on load, highway speed and more. Changes in shifting behavior can impact mpg. Huge? Not by a large factor, but I've seen it while trying to manipulate how it shifts by manually shifting and I can see mpg averages change.It’s just gonna make the reading more accurate it’s not gonna change the amount of fuel you actually use.
And of course, it will absolutely change the accuracy of the cluster display as far as current and average mpg. If it thinks you have only gone 20 miles but with bigger tires you've actually gone 25 - that's going to impact how it figures fuel used over distance.
