Bobchadwickga
- First Name
- Bob
- May 15, 2022
- 13
- 139
- 124
- Atlanta, GA
- 2022 Jeep Gladiator Rubicon
- Occupation
- Insurance
I got two KC Gravity® LED Pro6 lights that I am going to install with a Voswitch. From readings here, I won't be using the harness that came with the lights but will need to cut the plugs that connect to the lights from the harness and run my own wires. For each light will have one ground to a ground and one hot to the appropriate Voswitch switch (these will be run together so I am only using one switch).
The fuse on the wiring harness is 20amp. What gauge wire should I be using for a run of 10 feet tops. Also, their instructions have the ground to the battery. Is that necessary or can I ground it to the frame?
TIA.
Bob
TIA.
Bob
