- First Name
- Bill
- Oct 12, 2019
- 250
- 40,617
- 54,333
- Runnells, Iowa
- Occupation
- Vehicle Showcase
- 3
This is sort of Jeep related - it's a Jeep engine, and it's in a 4x4..........
1994 Jeep ZJ 4.0 liter engine, pulled from a totaled ZJ with 100,000 miles and rebuilt by me about 2010.
Since building the egine and getting things 95% squared away, the thing has run great - easy starting, smooth running no matter the temperature. No misfires. Then I decided that since the injectors had about 120,000 miles on them a couple of years back, I'd swap out injectors. I know they wear and so on and with all else being new, it was time. However, the only injectors I could find were "cleaned and rebuilt" on eBay. So I figured what the heck. It was never as smooth as with the originals but still ran ok.
A few days ago while moving things around to prep the car for a show (and making room to store my lawn tractor inside with the big grass catcher and cart), I found it was misfiring. I could feel it. A single cylinder. Started and ran fine (other than the jerking under load.
By now the engine has 35,000 on it since the rebuild and that means the plug wires have 135,000 miles and the plugs have 35,000 on them.
I figured I'd give it a thorough going over, new injectors (Benny helped me find the only set of OEM injectors in the country) new plugs and wires.
I found a fair amount of corrosion inside the #3 wire where it goes onto the cap, otherwise the wires "looked physically ok". Still, it's a lot of miles (135,000) and 32 years on the stock original plug wires.
I was hoping to take it to a Jeep/4x4 show but will miss that.
The plugs looked pretty normal as I pulled them, but #6 looked different - rich - in reverse order, starting with #6
While digging through my parts tub loaded with ignition stuff, I found 2 NOS (New Old Stock) original distributors and caps I had from Kenosha.
