surge101
Hey all,
First question: When most of you upgrade wheels and/or get bigger tires, what do you do with the spare? I'd imagine if you have a 31" spare and get 35" tires, the spare is essentially useless at that point? Do you get a tire of equivalent height for the spare (width would probably still be different if you changed wheels)? Or do you usually buy a 5th wheel/tire with your set and just replace the spare altogether?
Second Question: I understand that bigger tires affect the calibration of the speedometer. Can the dealer make this adjustment so that it is calibrated correctly? Is there any warranty issues? Are there any legality issues with calibrating it with an aftermarket device, also are there any legality issues with NOT calibrating it? The reason I wonder is I'm assuming a non-accurate speedometer would affect odometer mileage which I could imagine might be an issue when selling the vehicle? I also just wonder if messing with it ourselves is an issue for the same reason, even if our intent is to correctly calibrate it.
