- First Name
- Bill
- Oct 12, 2019
- 250
- 40,602
- 54,292
- Runnells, Iowa
- Occupation
- Vehicle Showcase
- 3
Combustion, normal or not, detonation or preignition - is IN the combustion chamber.Haha, isn't that the kicker, trying to describe a sound with written word. I'm not sure that the detonation is problematic intrinsically, sometimes it just happens on occasion and I'm sure it varies among all the different engines of the world.
However, I don't really know much about the affects of detonation over years and years of driving, I'd like to keep my truck for a very long time. Seems like combustion happening outside the chamber can put a lot of added stress on head gaskets and other engine parts not designed to be exposed to it. If this engine is designed to handle detonations outside the combustion chamber, then no- I doubt its problematic. Detonation is inefficient, and causes additional stress. I'd like to think that engineers would like to reduce both of those things over the life of a product. Haha but what do I know?
If we're unable to determine that its not to be worried about, or that it can't be fixed, I can think of 392 cubic reasons to just replace the whole thing.
Pre-ignition is when the charge is lit by something - pressure, heat, an ember, etc. before the spark, but it still is in the normal combustion chamber. It rattles because the charge is already burning, a flame front advances then a spark ignites the rest of the charge when it SHOULD be lit - and the two flame fronts collide - a sonic boom of sorts resonates in the block.
Detonation happens AFTER the normal spark - the advancing flame front from the normally burning charge compresses the unburned gases into a corner, so to speak - compressing it above normal range and creating heat in the process until the unburned part of the charge ignites - and another flame front approaches the normal one - boom - you get that ping or rattle.
What happens with detonation is that the colliding flame fronts blow the boundary layer off the top of the piston exposing it to the entire heat of combustion. Normally there's a very thin layer, the boundary layer, of the fuel charge that isn't burned. It serves as an insulation against the heat of combustion which is above the temperature at which the piston may melt. It also is more of an explosion instead of a calculated steady burn - which can literally BREAK things if it's severe enough.
Engines can survive periodic detonation. It's when it's loud, severe, and fairly steady, not "just occasional" that it does damage.
In any case, it all happens in the combustion chamber where the charge is normally burned.
I've got pages of stuff I've written and collected and examples, numbers, temperatures, etc. but won't get into that.
Good quench, swirl, turbulence, fast burn chamber design, all are ways to prevent detonation.
