Rear seat issues?
Artsifrtsi
Jude
Huntsville, AL
Resident Pompous A-Hole
My Canyon you had to flip the side lever to raise it, and then again to lower the rear seat bottoms. That would be a nice feature to have, especially if they made it lockable just like the seat backs.
fun2drum
Gary
Western NC
2020 Jeep Gladiator Sport S
Possible solution using a cheap Harbor Freight tie down strap:
Jeep Gladiator Rear seat issues? B1979C45-BCB0-4903-B4A5-F14EDA57D531
booneja
VI, canada
2020 Gladiator Sport (hers) and Overland (His)
RCAF Veteran/ Engineer
why not before buying straps, maybe try the seatbelt?? it might work, it might not, just saying if you want to try something that is already in the design of the truck use the seatbelt and might even lock if you are in hard braking......
fun2drum
Gary
Western NC
The twisted strap is killing me. I'm not OCD but I hate twisted ratchet straps if I can avoid it
Ha! Actually I hated it too, but there was a limit on how much time I was willing to spend on making it look great. It was raining on my back. lol
fun2drum
Gary
Western NC
Before I shot the above picture of the strap, I tried the seatbelt. It may have slowed down the seat bottom a little on its way down, but didn't stop it from moving.
AmishMike
Michael
Central Pa
Whipping boy
So long Trunk Monkey, Hello Seat Dog!
bastage
Idaho
If its something your going to be doing often I would just affix a strap to the bottom of the seat that would wrap around the headrest. When in the down position it would be out of site, but it would be easy to loop when ya need it.
Given that all gladiators to my knowlege come with some sort of storage under the seat wouldnt of thought it was intended to be left up. I appreciate how easy it is to raise & lower without a lever as I am often accessing both sides from the driver side reaching across so a lever or locking mechanism would of actually made things more difficult for my use.
Shackleton
Newbury, MA
Gobi Gladiator Sport S Max Tow, Camry
I looked quick earlier today and think a strap afixed to the underside of the seat would be good to have and then clip it to the headrest when in the up position. Not sure how to attach to the underside of the seat but I will look a little closer. I hadn’t given consideration to being able to flip the rear seat up from the drivers seat. On transfer station days I usually put the recycling in the back seat with the seats flipped up so no big deal if the seat falls on the recycling bin. I guess I had just gotten used to the way my old truck functioned though I did also store things under that seat as well.
bastage
Idaho
A piece of nylon webbing & then attach with some short flange head screws. I am not positive, but I would bet that the bottom is just plywood under the carpet and since its out of site nobody would be able to see them.
May also be able to use velcrow, or attach to some other point on the base & use some a longer strap. Hell could be real simple & use an appropriately length dog leash & then have a backup if your out with your pupper & forgot the normal leash.
Shackleton
Newbury, MA
Maybe the LATCH system can be utilized. I’ll figure something out and report back. It’s not pressing right now but I was thinking about it last night and thought I’d post
AUeng
NotAJeep :(
With regard to design intent, here's what the owner's manual says about the rear seats:
"The rear seat bottoms can be folded upward into the Stadium Position to create more storage space on the vehicle’s floor, and to access the under seat storage bins (if equipped)."
If it wasn't designed to stay up, and it slams down that it isn't a design flaw.
Just because some other brand stays up has no bearing on this.
If I had to venture a guess I'd say that most people put down a pad and have their dogs lay in the seat.
In any event. There is no argument here. I don't believe it is a flaw. If you think that it is than you should write a strongly worded letter to FCA. If they have had a significant number of complaints of seats slamming down on dogs while driving they will likely provide you with a repair or compensation. Or they might do nothing.
That being said, I provided a solution. Get a strap.
The bottom is meant to be storage - the seat is the lid. That's the design.
So STORAGE was the intended design - U R correct, no flaw.
Just because some other truck seat stayed up doesn't make this flawed because it's likely that OTHER truck seat came up for HAULING, not STORAGE.
This seat is a lid to a storage compartment, that was never intended to be lifted for hauling or carrying. Thus - no flaw. Totally different purpose truck, too. Can't compare.
(in case it was missed - I'm agreeing)
STORAGE space - not hauling of living things.
Me - I have blankets and rugs I toss onto the seats and toss stuff up onto the seat.
In any case it's very obvious just by lifting the seat bottom and moving it back down that it doesn't latch. I knew that from day one. It's too darned simple to just use a finger to plop it back down, I never did expect it to stay up - there's no latch.
brianinca
IT Manager
I've put everything from groceries to plastic tubs of gear in the back, the load held the seats up. If I don't want to hammer the lever cushion covers, then I flip the seats up or down depending upon clearance. No point in driving around with the seat cushions up otherwise.
