Recall # 21D - Anyone completed recall process for electric hydraulic power steering pump?
RHINO79
Jim
I’m going ahead and getting mine inspected as soon as Jeep can get it into service. 1 less thing I have to worry about IF I have an issue with a flaming Jeep. It’s been in, looked at, and I’ve got the documentation to prove it whether they say it’s good or not. When it comes to something that can take out a product worth $10k’s I want as much documentation as possible. Due diligence prevents getting dodoed on later.
If it needs a harness or pump, you will be leaving your jeep with them until the parts are available according to Dirt Road Cred YouTube channel if I remember correctly as to what they reported.
DiehardTory
Dee
Mid Atlantic
Retiree
The recall has the 1st step = Inspection of the wiring and connector at the Pump. Must be on a lift for tech to inspect. If NO pull back or burn on the wiring or connector.. Recall is completed. If wiring or connector shows any irregularities then the 2nd step is required = replace the wiring harness and the pump. Mine was done last week and all was OK, No further action required.
BTW I know the tech personally, he is fully certified by FCA / ASE fully certified, and I was under the Mojave when he inspected and he highlighted the areas of the inspection.
RHINO79
Jim
Lucky you, that tech sounds extremely rare.😃
