"Tow Mode?" and Static noise while towing
Mkelley
Michael
Ocala FL
Jeep Gladiator
Business owner
The JT's systems actually know the torque being applied and needed. It senses the weight and that you are towing and adjusts things accordingly.
I have noticed that with mine, it takes about 2,000 pounds to make it really understand it's towing.
It's a wimp with my empty car hauler, but has a very different personality when my trailer has a car on it.
Tow mode/sensing is automatic. No button, nothing to do.
Here's an example in the PCM's determination on whether or not to use ESS - it senses that it's not towing -
ESS Allow Engine OFF status:
Transmission OK: Yes
Tow/Haul OK: Yes
Intelligent Battery Sensor (Q): No
Intelligent Battery Sensor (V): Yes
Intelligent Battery Sensor OK: Yes
Pedal OK: Yes
HVAC OK: Yes
Engine Oil Temperature OK: Yes
and here's from another live log I took of mine showing it sensing the engine torque output-
Actual engine - percent torque;07/18/2022;09:53:19:85;18
Actual engine - percent torque;07/18/2022;09:53:20:97;18
Actual engine - percent torque;07/18/2022;09:53:21:90;18
Actual engine - percent torque;07/18/2022;09:53:22:94;19
Actual engine - percent torque;07/18/2022;09:53:24:44;18
Actual engine - percent torque;07/18/2022;09:53:25:36;19
Actual engine - percent torque;07/18/2022;09:53:26:67;19
Actual engine - percent torque;07/18/2022;09:53:27:61;19
Actual engine - percent torque;07/18/2022;09:53:28:66;19
Actual engine - percent torque;07/18/2022;09:53:29:59;18
Actual engine - percent torque;07/18/2022;09:53:30:59;18
Actual engine - percent torque;07/18/2022;09:53:31:75;18
Actual engine - percent torque;07/18/2022;09:53:32:78;18
Actual engine - percent torque;07/18/2022;09:53:34:04;19
Actual engine - percent torque;07/18/2022;09:53:34:97;18
Actual engine - percent torque;07/18/2022;09:53:36:00;19
Actual engine - percent torque;07/18/2022;09:53:36:99;19
Actual engine - percent torque;07/18/2022;09:53:37:96;19
Actual engine - percent torque;07/18/2022;09:53:38:98;22
Actual engine - percent torque;07/18/2022;09:53:39:97;23
Actual engine - percent torque;07/18/2022;09:53:41:23;22
Actual engine - percent torque;07/18/2022;09:53:42:19;24
Actual engine - percent torque;07/18/2022;09:53:43:38;30
Actual engine - percent torque;07/18/2022;09:53:44:27;31
Actual engine - percent torque;07/18/2022;09:53:45:17;29
Actual engine - percent torque;07/18/2022;09:53:46:51;15
Actual engine - percent torque;07/18/2022;09:53:47:44;25
I have a 2021 3.0 eco diesel and I can't pull nothing without my "red lightening bolt" popping up on my dash saying service electronic throttle body then it sends a check engine and puts me in limp mode.
