2021Rubicon Diesel Front Springs on 2020 Max Tow
Simba JT
Simba
McLean VA
Gladiator JT
Looking to install a set of 2021Rubicon Diesel Front Springs:
68506251AA and 68506252AA
on my Gas 2020 Sport S Max Tow.
Any issues with fit or quality of ride?
thanks in advance...
rharr
Tucson, AZ
I doubt it, fit would be the same as gas, they might be a touch stiffer then gas, but not by much as they are to soft for the ecoD. I would also install the diesel springs in the rear to have spring rates that are matched
The Max Tow feature would be lost. Would the front ride higher with the diesel springs?
rharr
Tucson, AZ
Max tow is stupid, all you are paying for is upgraded axle tubes that are thicker and wider then sport, maybe a bump in rear spring rate. Spring rate going from MT to ruby is probably inconsequential, there are tons of guys towing with lift kits and after market springs that haven't destroyed their rigs because it violated some goofy jeep option that people think is the word of god.
The front may ride a touch higher because the diesel spring rate is alleged stiffer, thus why i said do the rears too, and if it does ride higher, get some pucks for the back to fix it.
I say swap what ever springs you want and see what happens.
Mac
MA
2020 JT Hydro Blue Max Tow
Biggest thing with the max tow for me was getting the 4.10 gears, they work better with 35s than the 3.73s.
rharr
Tucson, AZ
Yes max tow is basically ruby axles without the lockers, not a bad upgrade.
