ABS bleed using Jscan
jc99
jc
Vancouver
2021 JTRD
I did an ABS bleed using Jscan but it only cycled fluid through the right front and right rear calipers then said complete. Anyone else done this? I was expecting all 4 to be part of the procedure.
Chance575
Chance
Earth
Diesel Jeeps..and a bunch of other junk
Trash collector
If you’re worried just go find some gravel and make a couple hard stops and get the abs to activate. Then bleed again. Rear brakes don’t do much work anyway
jc99
jc
Vancouver
2021 JTRD
Done that. Also the abs bleed and multiple regular bleeds. Still mushy pedal, always been like this. Might replace the master and see if that changes anything.
Vtur
Le
Norcal
JTOD
Electrical Foreman
That’s normal.
\/\/0j0
Knoxvegas, TN
2021 JTRD Sting Gray, Stock for now, 1997 TJ 4BT swapped
I get around
Yeah, it says right front and rear but you just repeat the process on the left and ignore the fact it says right instead of left
