kd1yt
My JT is the most fully and completely "hub-centric" wheel-type vehicle I've had, in terms of tight clearances between wheel and hub at hub center.
I discovered that the hard way this spring.
I'd bought the truck in August '19, and then installed dedicated snowtires on dedicated OEM (clean takeoff) steel wheels (with the steel-matching center caps covering the actual hubs) in late Fall of 2019.
Due to the extent to which 2020 turned out to be a "total, nothing, nowhere" year I was driving comically few miles in 2020, so I left the steel wheels and snowtires on until Spring 2021. And then I discovered that what I would ordinarily consider inconsequentially minor, outwardly un-detectable, corrosion (I do live in roadsalt country) had kind of oxide-welded my steel wheels to my hubs - even after some penetrating oil, it took a lot of pounding to free the wheels. Did the technique of jacking the wheel just off the ground, putting an 8X8 timber against the base of the wheel/tire, and swinging at it with a sledge, but it took a surprising amount of slams and force (and then got a wheel alignment to make sure I hadn't knocked things out of whack)
When I put my summer alloy wheels on, I put on some good-grade red multipurpose grease, smeared on the flat surface and around the center round portion of the hub.
But I'm wondering, does anyone have any other favorite products or techniques to keep the wheels from adhering to the hubs?
I'll probably never again leave wheels on for that length of time, since I change between summer/winter wheel and tire sets. But I _never_ want to have to give anything a beating like that again just to get wheels off.
