Bed Power - Main Battery?
Mjolnir
Alex
Dirty Jerz
2015 Willys, 2020 Gladiator
One of the few things I can't seem to find no matter how hard I try. My question is two-fold:
1. The bed power outlet is connected directly to the main battery, correct? This is fairly obvious but just want confirmation of this.
2. If #1 is true, like I assume, is it possible to rewire said wires to a secondary battery (Genesis dual battery kit).
Thanks all!
Thanks all!
A dual battery setup is the way to go. The outlet in the back cannot easily be converted to run on the auxiliary battery. Since it is only a 400 watt inverter, installing a larger inverter running off the auxiliary battery would be a better plan.
Mjolnir
Mjolnir
Alex
Dirty Jerz
Already have the genesis kit installed so there's that.
Guess I'm really just looking for how to rewire the stock bed power to the secondary
Beowulf
Jeep Wrangler Rubicon Unlimited
Where is the inverter? Can it be upgraded?
It is located under the steering wheel, above the brake pedal. There is no upgrade path provided for the factory 400 watt inverter.
