Broken Body Mount Installing Sliders
TomJT
Southern NH
2022 JTR
I was watching the Rock Hard 4x4 video on installing their slider and the guy in the video mentions "some customer hit them with an air gun", so I did. I have now broken the passenger side rear most body mount.
I went to a large auto body shop and they weren't sure what the best way to fix it would be. Lifting the body off the frame some, making some space from the bottom or going through the floor. They (specifically one guy there) has fixed Jeep body mounts before but not this one.
Has anyone else broken this body mount and had it fixed?
Thanks
Pickle_Bill
SE NH
2021 Jeep Gladiator Mojave
I have only seen the going thru the floor method. Not to say there may not be other ways.
Sorry you are going thru this. For anyone doing this in the future, an Induction bolt heater is recommended to heat up the loctite on those bolts, and the carefully removing them by hand. impact guns not approved for these bolts. :)
Free2roam
Robert
Anytime you have to mess with the body bolts get a bolt heater. It melts the red loctite and are much easier to get out. Plus NEVER/EVER use an impact on them. I see you learned that the hard way.
zuki_dan
Daniel
NC
92 miata & cherokee, 06 ram 2500, 15 mustang,
Aircraft Examiner
If it is the rear most bolt and it broke close to the threads you can unbolt the body mount from the frame and get an easy out socket in the remaining piece. I had it happen on my truck doing the rockslide engineering step sliders. That will only work on the 2 rear most body mounts though the front 4 I believe you will have to go thru the floor.
TomJT
TomJT
Southern NH
2022 JTR
Update: I put a camera through the bolt hole and saw the cup was still right side up in there. I moved it around with a coat hanger to line it up. I used the factory tapered bolts and not the new ones that came with the RSE step sliders and did an odd twisting while pulling down motion. I caught some threads and then used a wedge on the washer to continue pulling down while threading the whole thing in. I think this is good enough as I don't think the welds on the little cup are doing that much if they break that easy.
Zachattack50
Zach
West Michigan
2022 JT
Small business owner
Glad you got it sorted, I had to cut access windows in two of my front 4 body mounts to get to the trapped nuts. PITA
