Cross Tire Rotation as per the manual or side rotation only. 35x12.5x17
Uparms
I thought i asked my tire installer about this and will check in again now, but asking YOU ALL........
Are you rotating your tires as per the manual with a cross front to rear method OR just doing front to back and vice versa on the same sides??
Thanks all,
Uparms
Uparms
Installer just said stick with the Jeep manuals recommendation. Let me know your thoughts if you disagree.
kevman65
H
J
If you have directional tires, then you can't do the cross pattern.
Bjeepz
B
Canada
2025 Willy's
If doing a 4 tire rotation just follow the manual. If you are doing a 5 tire rotation with a full sized spare theres a ton of graphics on google that show the pattern.
Uparms
Uparms
Thank you all, did the 4 tire rotation at 5K on the new BFGs. Great test drive.
