Ear buffeting and relief vent noise/flutter after alucab and seat delete
Gatorized
ME/NH
This is what I’m working with
As I said last night I have the earlier version of the canopy and it looks like I have about the same gap as the OP without any buffeting. I do leave the crossbars on all the time but I don’t know if that comes into play.
Looks like @smlobx might have a slightly wider gap from cab to canopy. Is this adjustable at all - more to the rear to widen the gap?
Has there been any front end mods that would modify the airflow over the grill/hood/windshield?
Does opening the windows eliminate the buffeting?
I’m wondering if a small air dam at the top of the canopy would be enough to divert the airflow… like you did with the cardboard, but from the canopy forward different lengths/angles to see how narrow the gap needs to. be to stop the buffeting.
someone else mentioned a plate between canopy and bed rail gasket to extend toward the cab. For a down low air diverter - maybe only needs to be a little wider than the cab vent to divert airflow to the sides away from the vent.
Gladiator Brad 704
Mooresville NC
Put a fin on top of the cab. Something that can be taped on. My 2021 2500 HD chevy has something like this. Google it. You might be able to get something off of another car or truck. I had a similar result from adding a Soft Topper. I was able to move the Soft Topper closer to the cab and it resolved 99% of the problem.
You might be able to use type of heavy rubber mat. Stick it onto the cab and the camper top.
mopar 1957
Jerry
Ohio
I have basically the exact setup as you do with no problems at all. My cap has the windows and last fall I traveled the TAT without any of the sound you are describiing. The trip back to Ohio was all highway.
I had taken out the rear seats and made my own platform in the back of the cab. The only real difference is I have installed the cross bars on the roof of the Alu-Cab. This might be a course to consider.
Good Luck!
TarheelJT
Sean
23 Mojave
OP any updates on this fluttering issue ?
Apothum
Apothum
North Carolina
2023 Jeep Gladiator
Hi, updating this with the results. So as stated earlier the tubing in between the cab fixed the issue, but was a poor solution. I ended up installing a fairing that bridges the gap and this entirely fixed the issue. Here are the parts I used:
- Alu-Cab Load Bar 1250mm - Black
- Alu-Cab Low Profile Load Bar Mounting Feet
- Rhino-Rack Wind Fairings - 50 Inch
- 3M Clear Paint Surface Protection Vinyl Film
Obviously the feet then are resting on the top of the cab and rub. To lessen the long term damage I installed small strips of the film under the rubber feet. If they get dirty, they will occasionally squeek when the cab is rocking, so clean it off.
I am happy with the solution for now, although obviously not great that I felt the need to do this or my ears would have driven me to buy a tacoma. No data on how many MPGs this is giving me, but I feel like I am able to take corners much faster now.
Jeep Gladiator Ear buffeting and relief vent noise/flutter after alucab and seat delete IMG_7898
Jeep Gladiator Ear buffeting and relief vent noise/flutter after alucab and seat delete IMG_7899.JPEG
Gatorized
ME/NH
You can probably move that deflector back away from the cab so it is not rubbing on the cab. Let the front edge hang into the gap and it might solve the problem without the potential for paint damage.
TarheelJT
Sean
23 Mojave
I've been researching a lot and this is the first time I've read anyone having this fluttering issue with the Alucab. I'm wondering is the seat delete doing anything causing this?
smlobx
Eddie
Mid Atlantic
Semi retired consultant
I have deleted my rear seat and built a platform. I also have one of the first Alu-Cab canopies and haven’t had these issues…
TarheelJT
Sean
23 Mojave
Definitely strange. Glad OP has found a solution.
Apothum
Apothum
North Carolina
2023 Jeep Gladiator
Yep I acknowledge it’s weird, and I am probably sensitive to it with a history of tinnitus. Was definitely a problem however and have video of the flaps fluttering on the highway and slamming open and closed. The fairing works, I think it’s safe to buy if you are a normal person and at least if an issue you know how to fix it now.
