MrBones
Exactly why I only used them on my Cobra. It thrived at 6200.That catch is that when it's dirty, it's a problem for letting air through. Yes, a filter filters more/better as it gets dirty, but the amount of air going through is restricted.
Jeeps aren't performance vehicles, race vehicles, or needing "more air" than the factory or a good quality paper filter can supply. The CFM flow just isn't that high.
Another video out there shows a guy using a K&N on his Ford pickup - and showed on the dyno how yes, it was marginally better for hp and torque - above about 5,000 RPM.
So - how many here run their 3.6 over 5,000 on a regular basis? Most seem to cringe when it hits 4,000 RPM.
As far as "seat of the pants" changes - LOL - full frontal placebo. You aren't pulling enough air through that thing taking off from a stop to notice any real difference with a gas engine. Valves are in LOW LIFT mode at that point until you get 3,000 RPM and by then, you won't be paying attention to notice any "change".
I run dual quads on a 360 with a comp cam and pull through a heck of a lot more air than these little engines can muster - and run less "filter per CID" than Jeeps do.
