Gear oil?
vst
Scott
Tennessee
Hey everyone so I recently bought a Jeep gladiator and it has 5.13 gears in it but I’m not sure when the gears were put in and the truck only has 8700 miles so not sure if the gear oil was ever changed after putting the new gears in so I’m going to change the oil should I use the regular weight 75-90 or something different since it has the 5.13’s?
Randonexplosion
Randon
SW Colorado
2022 Gladiator Rubicon Diesel
The gear ratio doesnt matter as far as the weight of the oil. The difference would be if it has a limited slip or if you tow a lot.
Jteakus
Teakus
Oil City, LA
2020 JLURD, 2022 JTRD, 2017 JKU, 1983 CJ-7
Owners manual for the weight.
99.99% gear oil was changed when gear swap was performed. Go ahead and change it, will not hurt at all. Use the drain time to inspect for "stripper glitter" in the fluid.
  • Like
Reactions: vst
While not stated in the owners manual, Chrysler Tech Authority does state 75W-140 can be used if towing. Also, Dana spec sheets for their aftermarket sold Advantek axles also call out a 75W-140 grade.
  • Like
Reactions: vst
vst
vst
Scott
Tennessee
Im not going to be towing really much and as far as rear lsd I have a rubicon so not sure.
bleda2002
2021 JTR Firecracker Red
Rubicon's don't have LSD, they have a rear locker. If you tow, wheel, or live in a hot climate I'd go 75w140.
vst
vst
Scott
Tennessee
Do I need to add the friction additive since I have lockers?
No, electric lockers do not get the friction additive.
  • Like
Reactions: vst
bleda2002
It also won't hurt it if it does get the friction modifiers, some gear oils like royal purple just include it
  • Like
Reactions: vst
vst
vst
Scott
Tennessee
Thanks for the info
Sduncan
Shannon
Bakersfield,Ca
2021 Gladiator Rubicon Diesel
Valvoline 75/140 synthetic in the bag. Best idea in years for getting oil in differentials
Minty JL
Jeremy
Ft Meade, MD - AOR
Wait til you see the apparatus I came up with for doing diff fluid refills
Similar threads
