Front diff gear oil
  • Thread starter Deleted member 30519
  • Start date
  • Watchers 2
So I've started a couple of threads about this but didn't really get much of a response so I'll try again. I got 5:13 gears installed in August and got the rear diff fluid changed after 500 miles but was advised by the mechanic that I could wait to get the front changed if I'm not going to be using the four-wheel drive much. Since then we've had a couple of bad hurricanes and a couple of bad storms so I've used it a little more than I thought maybe around 125 miles in four-wheel drive. My question is should I wait now with the winter here in New York or should I just go ahead and finally get it changed now? Thanks
rharr
Tucson, AZ
if it makes you feel better change it. 1/2 hour of time and 25 bucks of oil, your call.
So I don't get roasted, you should pop the cover after you drain it and wipe out the bottom of the diff.
The dif cover gasket is reusable.
Jefe1018
NV
I have no real experience here, but changing the gear oil out a little early is not likely to cause any harm unless the exchange is botched. Waiting a little too long might cause some harm, it's really about how comfortable you feel.
WXman
Bluegrass region of Kentucky
So the front has never been changed since the gear installation? I'd change it. Like he said, it's quick and cheap so why not?
hjdca
Southern California Mountains
I think 125 miles in 4wheel drive with over 500 in 2WD is Plenty of miles on it to qualify for a first change of the front diff. fluid... Remember, unfortunately any excess metal powder in the diff fluid negatively effects the locker sensors in the Rubicon. In a Rubicon, it is best to keep the diff. fluids completely metal powder free.
jay21mojave
J. T.
S.E. Pa. West Chester County
2021 Mojave Gladiator 2013 JKU Sport '09 Patriot
Sales Acct Mgr - OEM Wholesale DLR Group
Thanks guys. I'm gonna get it done this week.
Here is a tip... loosen the fill plug before you drain the lube... and use the lube the gear mfg specified.
Similar threads
Replies
Views
1,082
Replies
Views
3,536
