Andy29847
Andy
South Carolina
We had a long running thread with a lot of contributors trying to settle how the 2 Jeep batteries worked together and what actually happens when the "Start" process is initiated. Below is a synopsis of the discussion. I am also including the link to the thread in the case you are bored and you want all the details. https://www.jeepgladiatorforum.com/...teries-really-isolated-during-ess-stops.87524
Late model Jeeps with batteries have 2 starting regimes. Let's call the first one "Cold Start." This does not mean that the engine (or weather) is cold. :) For our purpose, a cold start is one where the vehicle ignition was in the "off" position when you start. When pressing the start button on a cold start, the first thing that happens is that the Power Control Relay separates the 2 batteries. This is for the purposes of testing the auxiliary battery to determine the suitably for a future ESS start. The relay rejoins the 2 batteries in a very short time (~40ms). Once rejoined, both batteries are used to start and run the Jeep.
Actual oscilloscope test for cold start:
Jeep Gladiator How the ESS / battery system works - 3.6 engine i-SFSj7bQ-X3
Simplified illustration for a cold start:
Jeep Gladiator How the ESS / battery system works - 3.6 engine i-NG62Ln9
The second starting regime is an ESS start. The is where you are driving, you stop for a light, sign, or traffic, and the Jeep turns off (when you reach a full stop with the brake depressed). When you are ready to resume your drive, you let off the brake and the Jeep automatically restarts. When you make a stop with the ESS system turned on, and the engine shuts down, the 2 batteries remain connected together until you release the brake. Both batteries are keeping the electronics in the cab going. When the brake is released, the Power Control Relay separates the batteries. When the batteries are separated, the auxiliary battery powers the vehicle electronics, keeping things like the radio and AC on while you wait. Next the starter is energized solely on the power of the main battery. The batteries remain separated until the engine is started, and the starter turns off. Once the starter turns off, the Power Control Relay rejoins the batteries.
Actual test for ESS start:
Jeep Gladiator How the ESS / battery system works - 3.6 engine i-q8mtC4N-X3
Simplified illustration for ESS Start test:
Jeep Gladiator How the ESS / battery system works - 3.6 engine i-3HsWdNv
Revelations?
For the purpose of a cold start, the 2 batteries function as one.
In an ESS Start, the auxiliary battery powers the vehicle electronics while the main battery starts the engine. The time that the batteries are separated on an ESS Start is decided by the time it takes to start the Jeep.
If you are running your Jeep as delivered (with 2 batteries), and you get an ESS Stop/Start message or the infamous Avengers warning light, this might be your first signal that your batteries are nearing end of life.
If you are running your Jeep with the auxiliary battery removed, then you should disable ESS Stop/Start. The reason for this is that when you experience a low battery condition (old or discharged battery drawn down by the power needed to run the starter) you might get a Powertrain Control Module (PCM) reset and error code. You could also damage some of the sensitive vehicle electronics.
Funny thing - it took 20 pages elsewhere to finally get it accepted - that's what's been said for years........... and shown in voltage tests and FCA documents.
Andy29847
Andy29847
Andy
South Carolina
For me, acceptance was not the issue. The issue was so much wrong information floating around on the forums and how to pick what is correct. Evidence of that is on display in our original thread. Even after we have settled this part of how things operate, I've found it necessary to refine the writing for this post. I changed the term "cab electronics" to "vehicle electronics" and I changed the title to specify the 3.6 engine.
CKayaks
Cass
Montana
2025 Gladiator Willys; 2010 Nissan Xterra Offroad; 2018 Ram 2500
Nice!
Clear. Concise. With data. Thanks!
No need to change it now, but -
it's really the entire electrical system EXCEPT the starter circuits.
Electronics implies the computers, radio, that sort of thing, where it's also lighting, HVAC and so on.
And - it's not just the 3.6, but anything with "dual batteries" - including the diesel.
Andy29847
Andy29847
Andy
South Carolina
You are too smart to be posting lines like this. Some Jeeps have 2 batteries, but the batteries, starting, and charging systems are different than my Jeep.
How is the starting system different with your Jeep?
How is the charging system different with your Jeep?
You have gone to a single battery - but unless you got rid of the starter relays (both of them) and a different starter.................. and changed out the charging system - isn't it the same system?
You said this sequence in the original post was for the 3.6 - but it's the same for the eco-diesel as well.
The documents cover both engines.
Andy29847
Andy29847
Andy
South Carolina
I’m guess you are thinking just Gladiators and I am think all Jeeps. I’m ok if you call the win on this one.
I’m guess you are thinking just Gladiators and I am think all Jeeps. I’m ok if call the win on this one.
Dammit it dude, you'd be a hoot to meet some day. Maybe if we ever get to NC and check out where Eustace lives, and hit Florida again.
Yeah, our 4xe doesn't even have a starter, there's no alternator, and I guess you could say it has multiple batteries, but don't even think of connecting them together directly in parallel unless you love big booms.
PS - I went back and re-read your other message - I thought you were talking about YOUR Jeep, but you were talking about OTHER Jeeps.
My bad.
Andy29847
Andy29847
Andy
South Carolina
My bad.
We are on the Gladiator forum. I wasn't being clear. You are the winner. :)
sharpsicle
Tampa, FL / Milwaukee, WI
So, what happens if your vehicle is a 6-speed transmission with the ESS disabled and you kill it? Does your vehicle know what to do in that scenario? Mine doesn’t seem to…
....what?
Sounds like that has nothing to do with ESS.
This is why these threads become hard to understand.
To make this a little clearer, what happens if your vehicle has a 6-speed transmission and you have the ESS disabled and you kill it when you start to pull out or start backing up? Does your vehicle know that it should start back when the ESS button is pushed? Mine doesn’t seem to… I have to open my door so it completely resets the ignition system before I can start the vehicle back.
What? You have ESS disabled, you kill the engine, and you actually believe ESS will restart it for you?
LOL
NO
You killed ESS, you killed the engine, it's all on you and ZIP to do with ESS.
ESS isn't supposed to know that YOU killed it.
Buy them books send them to school and they chew the covers off the books as a boss I used to have might say.
ESS tracks itself, not what a driver does.
ESS restart is for an ESS shut down, not a driver who doesn't give it enough gas or lets the clutch out too fast and kills the engine.
I hope you don't really believe ESS is involved in any way - once you push that button to tell it to not shut down, it is ignoring you and the truck for the most part.
MNWillys
Minnesota
2121 Gladiator Willy's
Government
Revelations?
What happens if your ess battery is dead? I haven’t had the ess function working for me for the last 2 years and my truck sits a lot thru Minnesota winters. I only out about 5000 miles on it a year and do not use a trickle charger. Never had an issue starting my truck.
Your battery life will be shorter.
The more it sits with less than a full charge, the faster the capacity drops. A person who keeps them topped off under the exact same circumstances will see longer battery life.
If the aux battery is dead (it's not an "ESS battery per se"), then it disables ESS shutdowns.
That's about it. nothing is going to happen other than you don't have the help of the aux battery for a cold start and when the main goes, it's going to leave you needing help.
