How to remove this piece?? Skid plate for front upper control arm mount??
nicholsmf
East TN
2026 Gladiator / 2010 JK
Piece in question circled in white. Bolts circled in green came out with no issues. Bolt circled in red loosened up and now just spins. I can find a way to access the back side where a nut might be.
For orientation, front drivers tire is on left edge of picture.
Jeep Gladiator How to remove this piece??  Skid plate for front upper control arm mount?? 1000022088
Rockabillyroy
CA
JT
Looks like it might be behind the factory rail which is easy to remove.
Can you lever it with a trim removal tool or flathead screwdriver to apply pressure behind the bolt?
nicholsmf
East TN
Took the other side off to try to see how it works. Looks like 4 captive nuts welded to the inside of the frame. Seems like tre one that won't come out probably broke the weld for the nut. What a pain. Only 1,300 miles on this this.
Jeep Gladiator How to remove this piece??  Skid plate for front upper control arm mount?? 1000022090
nicholsmf
East TN
Looks like this piece is called a Tire Deflector Bracket. Had to cut the head off the bolt to get it off. Honestly it seems like a great place for moisture and debris to build up and cause corrosion.
My 20 doesn't have that.
BSW520!
Cleveland OH
2025 JT Willys Mojito / 2026 JLUR X Reign
Service Dept. Lead / Service Writer
Kfcanyonranch
Keith
Montana
2021 gladiator rubicon
Director of marketing
Sounds like the pressed in nut in the frame broke loose. You’ll need the cut the bolt or bolt head, remove tire deflector, and fish out the nut. This happens on skid plate bolt for me and I had to weld up my own hidden nuts, fish them into the frame, and replace the bolts.
